1 - 16 of 16 Posts
Ugh, I suck. I'm trying to sleeve my front panel cords and I popped out all the cords before writing down which one goes where - so stupid!
Anyways, I've figured out everything except for the HD audio and the Power/Reset/Led cords. I tried to google but couldn't find anything. Does anyone know the right order of cords here? Thanks!
Lemme take a look, mine are sleeved, but I might be able to give you some info as my front panel is off at the moment for some more modding...
Thanks dude! Can you give me a picture of your HD audio? Or just let me know the order of the wires (by color). For the power switch etc, I know which wires go to which part, i just dont know which is the voltage line and which is the ground.
OK, if you're looking at the front panel connectors for the audio, it should go from left to right:
Black, Blue, Green, White, Red, Orange.
Edit: Wait, you're trying to connect this BACK to the front panel, or actually the small connector?
OOOOOOH, that's a different story. Give me a second to run back upstairs. I gotta write this down and I'm not dragging that hernia box back down here with me, lol.
Okay, looking at the connector, the face says HD AUDIO:
1. Big black/small black
2. Small Black
3 Orange
4. Blank
5.Grey
On the backside (flip over and look at directly):
1. Blue/Blue
2 Black
3 Yellow/Yellow
4 Red/Red
5 Brown, Brown
Discussion Starter #9
Thanks!! Sorry to bug for one more thing...can you get me the order of power button etc connections?
I can figure out which cords go to which thing, for example I know which 2 cords go to the power button, but I don't know which of the two should be ground. Or maybe i can just test it to figure out...
Sorry, I was a little busy last night and didn't get to see your post. When I get home from work tonight I can post the rest of the connectors.
Discussion Starter #12
Originally Posted by crosshairiv View Post
dont they label the colors in the manual?
if anything you can try to trace it back up to the top if its doable
No the colors aren't labeled in the manual, I checked. Anyways, that part I'm done with - I just need to figure out the power/reset switches, and LEDs. I know which 2 wires to go which switch/LED but I don't know which are +/-.
Thanks XNine
I really appreciate the help!!! (I tossed you some rep in case I didn't mention before)
Thanks XNine
if it doesnt work just switch it around
1 - 16 of 16 Posts
