1 - 6 of 6 Posts
Corsair Air Series AF140 Quiet Edition CO-9050009-WW Case Fan
Description:
The Air Series AF140 fans let you have it all. Eleven ultra-thin, custom-molded blades push ample air volume. Rubber corners dramatically reduce vibration. The advanced hydraulic bearing system is quiet and reliable, and you can customize the look with the three included colored rings.
Details:
DetailValue
BindingPersonal Computers
BrandCorsair
EAN5052883649307
FeatureFan Size 140mm x 25mm
Noise (dBA) 24 dBA
Airflow (CFM) 67.8 CFM
Static Pressure (mm/H2O) 0.84 mm/H2O
1150 rpm
2 Year Warranty
Power Draw (@ +12V) .1A
Three colored rings in red, blue, and white.
LabelCorsair
ManufacturerCorsair
ModelCO-9050009-WW
MPN843591018234
PublisherCorsair
SKU205572
StudioCorsair
TitleCorsair Air Series AF140 Quiet Edition Single Fan (CO-9050009-WW)
UPC843591018234
CatalogNumberList - CatalogNumberListElement##-CORSAIR-PC-BOX-CO-9050009-WW
123339
11.544444444444444
CO-9050009-WW
16765
8105-CO-9050009-WW
Item Height1.77 inches
Item Length6.02 inches
Item Width9.25 inches
NumberOfItems1
Package Height1.89 inches
Package Length9.06 inches
Package Weight0.62 pounds
Package Width6.46 inches
PackageQuantity1
PartNumber843591018234
ProductGroupPersonal Computer
ProductTypeNameCOMPUTER_COOLING_DEVICE
UPCList - UPCListElement843591018234
Item Weight0.53 pounds
TotallydubbedHD on YT
Amazing air flow!
review by totally dubbed
These babies are amazing!
They provide high air flow in/out of your case, and still remain super silent whilst doing so.
I run mine between 700-1000 RPM, and I can't even hear them, unless I put my ear right next to it.
In the package you'll receive:
-Fan
-3 rings (red, blue and white)
-Four Black screws
-A 12v-7V step down reducer
Overall, these fans are definitely worth it, and much better than my Fractal Fans that came with my Define R4.
Here's my unboxing and overview of them:
ProsCons
EverythingNothing
Ratings
Overall5
It's quiet
review by nexo
I love it. They give you 3 color rings that you could choose!
ProsCons
It's quiet, you barely hear it unless you put your ear next to it
Ratings
Overall5
1 - 6 of 6 Posts
