1 - 2 of 2 Posts
Corsair Air Series SP120 High Performance Edition CO-9050008-WW Twin Pack High Static Pressure Case Fan
Description:
The wide body, low-pitch blades of the SP120 fans Twin Pack combined with the custom housing provides outstanding static pressure and airflow through heatsinks or radiators. With rubberized corners, a quiet and reliable Advanced Hydraulic Bearing, and an included step-down resistor for even quieter operation, the SP120 truly is the strong, silent type.
Details:
DetailValue
BindingPersonal Computers
BrandCorsair
EAN5052883630770
FeatureFan Size 120mm x 25mm
Noise (dBA) 35 dBA
Airflow (CFM) 62.74 CFM
Static Pressure (mm/H2O) 3.1 mm/H2O
2350 rpm
2 Year Warranty
Power Draw (@ +12V) .18A
Three colored rings in red, blue, and white.
LabelCorsair
ManufacturerCorsair
ModelCO-9050008-WW
MPN843591014281
PublisherCorsair
SKU11-166736
StudioCorsair
TitleCorsair Air Series SP120 High Performance Edition Twin Pack Fan (CO-9050008-WW)
UPC843591014281
CatalogNumberList - CatalogNumberListElement16764
123344
CO-9050008-WW
17.935
8105-CO-9050008-WW
Item Height3.54 inches
Item Length5.23 inches
Item Width8.58 inches
NumberOfItems1
Package Height3.7 inches
Package Length7.8 inches
Package Weight1.25 pounds
Package Width5.3 inches
PackageQuantity1
PartNumber843591014281
ProductGroupPersonal Computer
ProductTypeNameCOMPUTER_COOLING_DEVICE
UPCList - UPCListElement843591014281
Item Weight1.1 pounds
TotallydubbedHD on YT
Super cooling at low RPMs
review by totally dubbed
These SP120's are not only quiet, at full load, but also push quite a significant amount of air.
They keep my Antec 920 liquid cooler's radiator happy, even though the MAX RPM of these is only 1500RPM vs the stock antec fans that go up to 2500-2600RPM
I found the temps on my CPU to be exactly the same as my Antec's one, at full load (this includes gaming on Battlefield 3 & running Prime 95).
Long story short:
The SP120 quiet editions cool the same amount as the antec do - however the major difference is:
-Antec's are significantly louder at full load
-Antec's go to 2500-2600RPM, whilst this "only" goes to 1500RPM, and yet provides the same amount of cooling to the CPU
So if you're looking for quiet fans, that actually do their job, at a low RPM, and compete with temps of a fan that runs almost 1000RPM faster - then these fans are the babies to go for!
Highly recommended.
ProsCons
EverythingNone
Ratings
Overall5
1 - 2 of 2 Posts
