1 - 2 of 2 Posts
I have an AX860 Platinum and I was thinking of trading for an HX850i platinum because I wanted the iCUE monitoring of power consumption and output. What I wanted to know if there is much of a downgrade going from the AX to the HX. They are both platinum certified so that's goo.
The other main thing I wanted to ensure there is a ZERO RPM mode on the HX850i at light loads. My AX fan does not spin when the computer is not being loaded up and I want the same from the HX as my build needs to remain quiet. Is it possible to set the fan to zero at low loads on the HX?
Corsair Link software can control the fan RPM for the HX850i. But I'm not sure if it allows you set a fan curve or if it is just controlling a fixed RPM.
1 - 2 of 2 Posts
