1 - 1 of 1 Posts
Corsair Carbide Clear 400C Compact Mid-Tower Case, CC-9011081-WW
Description:
We've engineered the Carbide Clear 400C to pack all the performance and expandability you need into a beautifully modern and compact case design. Put your build on display through the gorgeous, full-size window panel, and keep it all running cool and quiet with Direct Airflow technology. With a one-touch side panel, tool-free drive installation, and three-point dust filter access, 400C is easy to build - and even easier to keep clean. You'll spend less time on setup and maintenance, and more time enjoying your PC. Corsair's Carbide Clear 400C perfectly balances desktop footprint, expandability, and affordability.
Details:
DetailValue
BindingPersonal Computers
BrandCorsair
EAN0843591068529
FeatureClean, modern lines with an all steel exterior: For those who want premium aesthetics, the 400Q has full steel front, side, and top panels for extra durability and gorgeous good looks.
Hinged and latched full side panel window: Easily access your components with a single touch - and when closed, enjoy viewing every part of your build through the fully side panel window.
Compact design, full size capabilities: Don't let the compact dimensions of the 400C fool you -- it can house a full ATX motherboard and multiple GPUs.
Liquid cooling capable: With room for front, top, and rear radiators, you can choose to quiet down your GPU and CPU with liquid coolers just about wherever you want to.
Direct Airflow Path: Drive cages are moved up and out of the path of cool air from the front intake fans and high-temperature components.
Two AF series fans: Corsair-exclusive AF120L and AF140L fans efficiently draw ample cool air directly to your components without the turbulence that can cause fan hum.
PSU and 3.5" Bay Cover: Clean up the inside of your case by placing cables and drives behind two modular, clean, and refined PSU and 3.5" bay covers.
Easy to Clean: Easily access dust filters on front, top, and bottom mean you'll never spend more than a minute getting dust out of your system.
LabelCorsair - IMPORT FOB HKG Factory 2
ManufacturerCorsair - IMPORT FOB HKG Factory 2
ModelCC-9011081-WW
MPNCC-9011081-WW
PublisherCorsair - IMPORT FOB HKG Factory 2
StudioCorsair - IMPORT FOB HKG Factory 2
TitleCorsair Carbide Clear 400C Compact Mid-Tower Case, CC-9011081-WW
UPC843591068529
ColorBlack
CatalogNumberList - CatalogNumberListElement90633924
LN69312
Item Height18.26 inches
Item Length16.74 inches
Item Width8.46 inches
Package Height11.3 inches
Package Length23.2 inches
Package Weight17.15 pounds
Package Width19.6 inches
PackageQuantity1
PartNumberCC-9011081-WW
ProductGroupPersonal Computer
ProductTypeNameCOMPUTER_COMPONENT
UPCList - UPCListElement843591068529
Item Weight14.55 pounds
1 - 1 of 1 Posts
