1 - 12 of 12 Posts
Originally Posted by ENTERPRISE1701
That RAM isnt to bad However IMO you will do better with something in the GSKILL or GSKILL HZ range.
If you can find the HZ series, it's been disciontinued.
Th DDR400 Ballistix OC good, just not as good as the earlier production pieces.
The HZ series has been in and out of stock for the last two weeks on Newegg. I ordered some last week and it should be here Tuesday
For the thread starter - the HZ is some pretty good stuff from what users have been saying. If you like you can keep an eye on the link below to see if it comes back in stock.
Like i said, it has been in stock then out of stock, back in stock and out of stock again in the last few weeks. This stuff goes fast so hopefully they get more back in.
G Skill HZ
Overclock Failed...
Originally Posted by LyokoHaCk
good oc ram?
That stuff usually tops out at about 220mhz. It can run 2-3-2-5-1T @ 2.65v at slightly over 200mhz though.
1 - 12 of 12 Posts
