1 - 4 of 4 Posts
Work Hard Play Hard!
CORSAIR Crystal Series 680X RGB High Airflow Tempered Glass
I picked up this case and am having second thoughts on the possible Radiator options.
I currently have 1 360 and 240 Radiator in my existing build I can move over but I really just wanted the MAX radiator profile for the case and I am thinking the case may not be designed very well for excessive radiators and cooling.
The new build is the 9900k and 2080ti all underwater on the ASUS ROG Maximus XI Formula Z390
Discussion Starter #2
The video card seems to take up a lot of room even mounting Vertical.
I was able to fix 2 Radiators.
After some work i was able to fit two radiators.
360 and a 240.
Damn that's tight!
1 - 4 of 4 Posts
