I sorted out the Micron Chips in the Corsair modules since the recent mixup, I took these from the Corsair complete list and cut out everything and sorted it nice and clear, but the Microns, but IDK if this is all of them...
These are all XMS2 Modules...
Ex:
CM2X1024 - 6400C4D XMS6404v1.1 0645065-1 = Micron, 64Mx8, 2-533 CL4, Rev D
The first bold set of numbers = Memory size
Ex: 1024
256 = 256 MB
512 = 512 MB
1024 = 1 GB
The example above is 1 GB
The second set = PC2 xxxx
Ex: 6400
so if the number is 6400 that means the memory is PC2 6400
The underlined part = Special features
Ex: C4D
C3 = Cas 3 rated timing
C4 = Cas 4 rated timing
C5 = Cas 5 rated timing
PRO = Pro set of memory, special headsinks with LEDS in them, "better" for OC
D = Dominator series, the newer Corsair memory for "great" OC and temp control
The above example is Cas 4 rated Dominator series
The third set of bold numbers is your memory version number
Ex: v1.1
The above is Version 1.1
When your seeing if your ram is Micron, or the Corsair ram you're buying is Micron, this number is the most important part...
Other (Twinx and such):
CM2X256A - 5400C4 5402v1.1 0508085-1 = Micron, 64Mx8, DDR2-533, CL5, Rev B
CM2X512 - 5400C4 5402v5.7 0635225-5 = Micron, 64Mx8, DDR2-667, CL5, Rev D
CM2X512 - 5400C4 5402V5.7 0628135-2 = Micron-ST, 64Mx8, DDR2-667, CL4, Rev D
CM2X512 - 5400C4 5402V1.4 0544117-0 = Micron, 64Mx8, DDR2-533, CL4, Rev B
CM2X1024 - 5400C4 5402v2.10 0628134-2 = Micron, 64Mx8, DDR2-533, CL4, Rev D
CM2X512 - 5400C4 5402V5.7 0625338-3 = Micron, 64Mx8, DDR2-667, CL4, Rev D
CM2X1024 - 6400C3 6403v1.1 0619028-4 = Micron, 64Mx8, 2-667 CL5, Rev D
CM2X1024 - 6400C4 6404v1.1 0635044-1 = Micron, 64Mx8, 2-533 CL4, Rev D
CM2X1024 - 6400C4 6404v1.1 0626099-3 = Micron, 64Mx8, 2-667 CL5, Rev D
CM2X1024 - 6400C4 6404v1.2 0620097-1 = Micron, 64Mx8, 2-667 CL5, Rev D
CM2X1024 - 6400, 6405 v1.4, 0606096-2 = Micron, 64Mx8, DDR2-667, CL5, Rev D
CM2X512A - 6400 XMS6405v1.1 0531093-0 = Micron, 64Mx8,2-533, CL4, Rev A
CM2X512 - 8000UL XMS8005v1.1, LOT 0539081-1 = Micron 2-733 Rev A
CM2X512 - 8500 XMS8505v1.3 0632173-2 = Micron, 64Mx8, 2-800 CL5, Rev D
CM2X512 - 8500 XMS8505v1.1 0613081 7 = Micron, 64Mx8, 2-800 CL5, Rev D
CM2X512 - 8500 XMS8505V1.1 0610102-0 = Micron, 64Mx8, 2-800 CL5, Rev D
CM2X512 - 8500 XMS8505v1.1 0610102-1 = Micron, 64Mx8, 2-800 CL5, Rev D
CM2X1024 - 8500C5 XMS8505v1.2 0620114-1 = Micron, 64Mx8, 2-667 CL5, Rev D
Pro:
CM2X512A - 4300C3PRO 4303v9.9 0540078-1 = Micron, 64Mx8, DDR2-533, CL4, Rev B
CM2X1024 - 6400PRO XMS6405v1.1 0610028-1 = Micron, 64Mx8, 667, CL5, Rev D
CM2X1024 - 6400PRO 6405v1.3 0610028-1 = Micron, 64Mx8, DDR2-667, CL5, Rev D
Dominators:
CM2X1024 - 8888C4D XMS8804v1.1 0634174-2 = Micron, 64Mx8, 2-667 CL5, Rev D
I know this list can't be complete, but it's very close to it, have fun
Ex:
Ex: 1024
256 = 256 MB
512 = 512 MB
1024 = 1 GB
Ex: 6400
Ex: C4D
Ex: v1.1
Pro:
Dominators:
