1 - 3 of 3 Posts
System is my sig rig. Havent OC'd yet, but I did bump my my ram up to advertised settings (8-8-8-24 @ 1600MHz)
It defaulted to 8-8-8-20-1T @ 1066MHz.
I set the command rate to 2T. Would it be okay to set it back to 1T? Im not sure what the stock command rate setting for this ram is.
yes, as long as its getting 1.65v, 1T is fine.
Reactions: shiarua
Yeah 1T will be fine.
It just defaulted to 1066mhz because 1066 is what the i7 runs at natively. Anything over that is technically an overclock for the onchip memory controller.
1 - 3 of 3 Posts
