Got this ram a little while ago & am feeling cheated. It works fine once I set the timings in bios, but I paid more money for the convenience of not having to do just that. Feeling like I should've just bought the Intel XMP version that was $50 less at the time that had the same voltage & timings.
I wrote a review on Newegg to share my frustration & experience with it & this was Corsair's response.
Manufacturer Response:We are sorry that AMD is not able to support BEMP at this time. We have done what we are required to do and provided them the profile information.
Also, keep in mind that your kit is the "B" version of the 1600C8 which is in fact tuned for better operation on the AMD platform. It is very likely that you would not be able to get the same level of performance from the "A" version. So, regardless of the lack of BEMP support from AMD, you did buy the correct version of memory.
Is this a legitimate claim? I would figure that if the primary timings & voltage were the same that it would be likely that the architecture would be the same. What do they "tune" differently. I'm just trying to wrap my mind around it at this point. Thanks in advance for any help. -Chizel
