1 - 1 of 1 Posts
I measured the new height to be 41mm (~41.1mm - just higher than 41), making it compatible with a fair number of extra coolers.
You need a hex key to get it open, and something like this (iFixit spudger) to carefully pry off one side of the heatsink with its thermal pad, in order to remove the top heatsink piece (held on by a weak adhesive). You can then stick the heatsink back on with the existing thermal pad, and replace the screws.
Reactions: puhadk
1 - 1 of 1 Posts
