1 - 7 of 7 Posts
Hey OCN.
i have a Corsair Dominator RAM kit ( CMT4GX3M2A2000C8 ) but now when i want some more, i cant find it anywere, the place i ordered it from says it cant be ordered cause its outdated.
so my question is, what can i get that will work with the sticks i already have ? i want to use the benefits from triple channel
Generally it's better to get matching sets because it decrease the risk of compatibility issues. Plus with ram so cheap these days, it'd probably cost you the same to get a new set versus trying to look for that lone matching stick.
Originally Posted by Darksoul844
Anything with the same speed just make sure its a good brand. And not sure if you can run dual channel ram with triple channel ram
When you buy a dual ram package or triple ram package, all the means is that its been tested in that configuration. You can still mix and match from different sets. I've done it many times in the past.
1 - 7 of 7 Posts
