So in my new build I decided to try out the corsair h100 CLC loop CPU cooler. A friend of mine has one on his sandy bridge set-up and he is able to do a really good over-clock in his 600D case.
Well I have heard a lot of mixed reviews with the h100 online but decided to try it anyways.
I bought the h100 and 4 cougar vortex fans for a push/pull configuration in my case, do you think this was a good choice? The next time I do a build I will most likely do a custom loop, but this time around I am very new to all this and I just want to take it 1 step at a time and learn the basics(This is my first real entire build from the ground up)
I am using a Cooler Master HAF X 942 case and currently my plan is to have the h100 mounted in push/pull at the top of the case in an exhaust configuration. Will this work the best? The air intake comes from the front via a 230mm front fan and 200mm side fan being the main intake, I also have the option of attaching a 120 or even 140 I think in the front as well to push more in faster. The exhaust on the case would be the rear case fan which is a 140mm and the top corsair h100 in push/pull exhausting.
Does this sound like everything should be great for moving air?
Is the Corsair h100 a good cooler? I have read it is on par with the noctua D-14 but it has benefits in that you can use tall heat-sink RAM which I am using (Corsair Vengeance) and it doesn't put really any stress on the mobo due to weight.
