So after building a new PC for someone else, I learned quite a bit about overclocking: speeds, temps, voltages, stress testing/temp-monitoring software etc.
Before I just used the ASUS one-click overclock and left it. Now I manually applied the following overclock with the following hardware.
Hardware
Case: Cubitek Mini Cube (Temporary while I cut holes in my Lian Li PC-TU100)
Motherboard: ASUS Maximus VI Impact
CPU: Intel Core i5-4670K
Cooler: Corsair H75 Liquid Cooler
-Using one Noctua 2000-RPM Industrial Fan
Overclock
Speed: 4.1 GHz
Voltage: 1.1 Volts
Temps: 85 C at full load
I'm new to overclocking and probably a noob, but this is a light overclock with a low voltage for Haswell. I don't know why the temps are so outrageously high.
Any help is appreciated.
Hardware
Overclock
Speed: 4.1 GHz
Voltage: 1.1 Volts
