link to UPDATE 4
link to UPDATE 5
link to Kdude6's h80 result
link to EM2J's h80 vs nh-d14 vs nh-c14 result
link to KaHuNaZ's h80 vs zalman cnps9700nt result
link to Munkypoo7's h80 vs h70 result
link to beefdog's h80 vs h50 result
link to lucas4's h80 result including scythe ap15s!
been holding out for an h-series cooler for a while now, was originally considering the h50, but got the frio instead. then it came h70 and h60, almost pulled the trigger on the h60, but heard h80 was coming out. so after weeks and weeks of waiting, bang, bought the h80 yesterday, and it's in store to pick up from today!!! would love to get it today, but i'm away from the city with family, so it'll have to wait till tomorrow.
not sure how the h80 will compare to the likes of nh-d14 or silver arrow, i know those h-series coolers aren't that amazing, but always wanted to give them a try, guess i will find out pretty darn soooooooon!
for those who are interested in the h80, stay tuned, i will test it as soon as i have it installed. shame i don't have anything to compare with other than my frio, but it's something at least
oh i'm getting pretty excited already, wish the coming 24hrs will fly-by
UPDATE 1 - UNBOXING PHOTOS
so finally got the time to go to store and get my h80, literally just got home and took some photos for those who are interested. gotta go for a football session soonish, so not gonna have time to install and test it until later tonight or early tomorrow (have a day off on monday
) will update more photos once i have the h80 installed
so here are some photos i've took just now, enjoy! and if anyone wants any different angled shots or whatever requests, just leave a reply, i'll try my best to answer!
http://dl.dropbox.com/u/23857814/PC/H80%201.jpg
brand spanking new unopened box
back of the box, it states 10'c improvement over h60, which worries me a little coz it's 2 fans vs 1 fan...i don't know how h60 performs with 2 corsair stock fans
maybe later when i get to test the h80, i will do a 1 fan test so for those who has an h50 or h60 you can compare the actual block/pump+rad better
packaging...standard i guess...
box content
block/pump unit, the button in the centre switches between the 3 performance profile, white led light will indicate which performance level is currently being set. the little man will only lit up when the h80 is paired up with the corsair link unit
the corsair digital link...need to do some reading on that, not sure how it all works yet. 3-pin motherboard fan connector and molex
2 4-pin fan headers to connect the two fans provided. the block/pump unit has a built-in pwm controller i believe
pre-applied paste, i will be using this to do the testing first, then i will probably use mx-3 or mx-4 i haven't decided yet
radiator fins, for those who are interested in how dense the fins are, i never owned any other h-series cooler so i can't really compare, i'd assume they're all the same to be honest
corsair fan, only 3-pin connector, but as i mentioned already, the block/pump unit has a built-in pwm controller so 4-pin fans are not required here
so, that is that, hope it's been an interesting read for you guys thus far. like i said already, if you want more photos or have questions, just leave a reply
out for now...more to follow later, stay tuned
UPDATE 2 - INSTALLATION PHOTOS
so here it is, i was gonna take photos as i install the h80 step by step, then decided to just show you guys the complete product, it's not a rocket science to install those h-series cooler anyway...
for comparison purpose, i threw in my frio setup, personally i still like the frio's look, but in my opinion it makes the rig look a 'little' crowded
so, took off my frio and top exhaust fan, ready to install! one note, due to the fact that my case only has 4 fans, 3x180mm intakes at the bottom, now that the top exhaust is gone, which leaves me no option but use the h80 fans as exhaust. i will see how temp goes, maybe later on i will turn the fans around
for those who expressed worries about cable management, i'd say there isn't much you have to worry about, the molex and the cpu fan connector can be easily 'hidden', well....semi-hidden, i think it doesn't look that bad. then there are those 2 fan cables that go into the block/pump unit, again, you can make them look ok-ish, i think they way i did it is not that bad, you guys may have better ideas too
and here is the final look, pretty happy with the way it looks this far, makes the rig looks quite a bit more spacious...
alrighty then, photo time is OVER, time to get some numbers up, next update will be i7 950 stock clock idle and ibt max + i7 950 @ 3.82 idle and ibt max...
sorry for those who have been itching to see some 4ghz+ overclocks, i'm having problem getting my 950 stable at 4, but strangely it did before, oh well, i guess it will have to be 3.82 for now, i will tweak some settings a bit more later on and see if i can get it to 4+ again.
also, since corsair tested the unit at 3.8 with a 920, would be interesting to see how my setup compare to that.
enough said, stay tuned, give me a bit more time, results will be up soon
UPDATE 3 - NUMBERS
ok, before i go any further, just to say this again that i used both stock fans as exhaust, and pre-applied paste was used.
first up, stock i7 950 performance with some voltage tweak. exact voltage settings can be found in any of the h80 stock screenshots on asus turbo v.
idle first...
this is my frio with stock fans in push/pull at approx 1800rpm
h80 at low setting
h80 at medium setting
h80 at high setting
now, intel burn test max, ht on, 8 threads, 5 runs, custom ram set at 4800
frio, same setting as idle
h80 at low setting
h80 at high setting
now move on to 3.82ghz, i've only done the high performance settings on the h80, as i have a dentist appointment, so other tests will have to wait...
frio, same fan settings, idle temp
h80, high setting, idle temp
frio ibt, same setting as before
h80, high setting, ibt temp
sorry guys, i don't have time to leave my thoughts here right now, really need to run for my dentist appointment, but i'm sure you all understand numbers...
long words put short...disappointed so far...
UPDATE 4a, 4b, 4c & 4d
link to UPDATE 4
link to UPDATE 5
link to UPDATE 5
box content
UPDATE 3 - NUMBERS
idle first...
h80 at low setting
h80 at high setting
h80 at low setting
h80 at high setting
link to UPDATE 4
link to UPDATE 5
