Fantastic!Originally Posted by compuman145;13139584
lol easily,
I was running the HX650 with my [email protected] + GTX570 +GTX275 6 case fans, my H50 and 6 gb of memory.
It's an epic PSU and you'll be fine
Comps
my suggestion to u,Originally Posted by Myrmeleon;13139560
Hi all,
Can my Psu Corsair HX 650 Modular to support a system with i5 2500k OC, SLI of 560ti both OC, 2 x 4Gb DDR3 1866 and 2 Hard Disk?
Thanks for the replies!
... um, no.Originally Posted by Aniket;13139712
my suggestion to u,
corsair hx750
dont take chance with 650watt,
I must admit corsair ax,hx,tx,gs line up psu are great
really i made that argument just today and had 2 people go on and on about how it wouldn't... or did you mean 560 instead of 570?Originally Posted by compuman145;13139825
... um, no.
The 650 is suitable for Sli GTX570's at stock.
I don't know if he made a typo or not but either way it would be correct, a 650W is fine for a pair of 570s.Originally Posted by phantasmor;13139894
Actually the TX650V2 is a better unit than the HX650, with the obvious downside that it's not modular.Originally Posted by UnexplodedCow;13139961
That's powered by a TX650V2, and pulls a little over 300 watts in a usual encoding spurt, or game. That is from the wall. If I slapped in another 5850 I'd be around the same power use, and have no doubts the 650 will hold it...yet it isn't the HX (which is supposed to be better).
thank you! i will quote that in my sig nowOriginally Posted by Shub;13139993
I don't know if he made a typo or not but either way it would be correct, a 650W is fine for a pair of 570s.![]()
Originally Posted by UnexplodedCow ![]() Matter of opinion there. I much prefer hard-wired connections; less chance for heat, resistance, or electrical noise. |
TX series (stop-gap) Enthusiast mid-range units, fixed cables, rated at 40C, Japanese caps, 80+, 5 year warranty. These power supplies replaced the original TX line in approx. Q3 2010. They perform slightly better, but there are questions about build quality. TX650-C - CWT PSHII TX750-C - CWT PSHII TX850-C - CWT PSHII (Some reports of alternate variations, unconfirmed) TX v2 series Upper-mid-range enthusiast units, fixed cables, rated at 50C, 80+ Bronze, 5 year warranty TXv2 650W - SeaSonic TXv2 750W - SeaSonic TXv2 850W - SeaSonic |
