1 - 3 of 3 Posts
I am looking to buy the Corsair Hydro Series H100. I currently have a HAF X case. The radiator has two 120mm fans in it. On the top of the HAF X there are two 200mm fans. I was wondering if there was a way that I could change the fans on the radiator to 200mm, or If there was some kind of kit I could buy to put on the case so that I could fit the radiator on the case without having to cutup the case. I would be willing to put the radiator somewhere else too if I could. I am providing links to both the radiator and the case so I someone wanted to look and try to help me out, they can.
Thanks,
Andrew Adsit
Case: http://www.newegg.com/Product/Produc...82E16811119225
Cooler: http://www.corsair.com/cooling/hydro...pu-cooler.html
1 - 3 of 3 Posts
