1 - 2 of 2 Posts
When I make the G-Keys open a destination folder, the folder window is never maximized & wont stay maximized after manually doing it. there is no options do fix this.
Doesn't do this on my g15 so it probably isn't windows.
Anyone have this issue on vista or any windows?
thanks
are you using the corsair software or a different program?
if using the corsair and the logitech, then yeah you may have some inconsistencies when trying to achieve the same thing.
1 - 2 of 2 Posts
