Got this mouse yesterday after a long waiting for availability. I bought this mouse because of the 3310 Sensor with 5000dpi (nativ setting for this sensor).
compare to a R.A.T above the M45 and among them the RAT
off center sensor about 5mm 3/16"
2500 is not correct, after I installed the software the 2nd dpi step is 2400.
Comparison images:
Size and weight:
without any weights, closures and cable 90gr approximately 96-98gr.
72 x 39 x 120 mm (W x H x L)
I do the tests with original FW, without software installed. Just plugged it in.
Accerlation:
I could not find any accerlation in paint tests.
Jitter and prediction:
for your assessment in the paint pics.
LOD:
with two CD's I no movement anymore.
(after I install the software you could pic out of 5 steps in scan hight; but the lowest is not lower than default - imo)
Perfect control speed:
I did test for the 2 other default dpi steps (2400, 5000) and I never get less than4,5m/s.
Subjective opinion:
The sensor performs very good in a 3,5 h BFBC2 session. Although the shape is not 100% for me, me and the mouse performs very well.
Feeling nothing bad at all. No moment of thinking the sensor did something I do not want.
Shape is not bad, but because the left side is a little higher the right mousebutto is to short for my palm grip.
The middle from the last part of my middlefinger is above the right mousebutton. I try to show this in the compare pics to the R.A.T. (RAT feels better)
The side material is a little rought and I like it for the good grip. The upper material is to slippery imo. Both traces susceptible (fingertips) very godd.
Without weight and closures the mouse feels a little front heavy.
Mousewheel is good; louder in upscrolling and dull (not negative). Steps are good to feel. Can make it clack only, if I pic the mouse up and shake it as fast as I can.
No clack for speed swings on the pad.
I dig not deep in the software but you could save your settings onboard. DPI steps of 50-5000 in 50.
The mousebutton 1 and 2 I really really like. Light, short in travel with a crystel clear not to loud click. Very good imo.
The sidebutton are a little too small, have a little to much travel and a little too much wobble. But still good enough for sidebuttons and good too reach. Mousewheel button is too heavy for me. Need to much pressure.
Doubt I could use it ingame without anger.
Later, I will open the shell check the pcb and more....
For shure this is my next modding base to put it in "my" Dell shell.
Hope you like my first review here. If you miss something, make a request here. I will see, what I can do for you.
Comparison images:
Size and weight:
Accerlation:
LOD:
Subjective opinion:
