1 - 2 of 2 Posts
Corsair Memory Vengeance 16 Quad Channel Kit DDR3 1600 MHz 240-Pin DDR3 SDRAM CMZ16GX3M4A1600C9
Description:
CORSAIR high performance Vengeance memory module 16GB (4x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a lifetime warranty
Details:
DetailValue
BindingPersonal Computers
BrandCorsair
EAN0843591011372
FeatureLifetime Warranty
Height0.63 inches
Length7.75 inches
Weight0.2 pounds
Width5.88 inches
LabelCorsair
List Price$299.99
ManufacturerCorsair
ModelCMZ16GX3M4A1600C9
MPN0843591011372
Package Quantity1
Product GroupPC Accessory
Product Type NameRAM_MEMORY
PublisherCorsair
SKUA7WD922
StudioCorsair
TitleCorsair Memory Vengeance 16 Quad Channel Kit DDR3 1600 MHz 240-Pin DDR3 SDRAM CMZ16GX3M4A1600C9
UPC843591011372
Number Of Items1
TotallydubbedHD on YT
Good price for the amount of GBs
review by totally dubbed
I found these sticks to be very good, until I discovered a faulty one.
Things like this happen all the time, but I would have expected it to be a little more sustainable, compared to cheap RAM out there.
OC'ing it is quite hard, you'll struggle to get it to CAS 8, with low voltages.
Long story short, a great bundle of RAM, but don't expect to OC it, and make sure you test it before playing around with anything else on your system.
ProsCons
Price, look, performanceReliability, OC'ing
Ratings
Overall4
1 - 2 of 2 Posts
