Corsair Professional Series Gold 750-Watt 80 Plus Gold Certified High-Performance Power Supply - CMPSU-750AX
Description:
The Corsair AX750 power supply is the highest-quality mid-wattage power supply for enthusiasts who want uncompromising performance. With 80 PLUS Gold certification, a fully modular cable set and low noise levels, the AX750 is unrivalled at its wattage.Unprecedented Power Protection The Corsair Professional Series Gold power supply pushes the state of the art for reliable delivery of clean power under imperfect conditions. If you require mission-critical stability or you simply want one of the best power supplies available, the Professional Series Gold is for you.A Fully Modular Cabling SystemAll cables detach from the power supply. During installation, this gives you the flexibility of using only the cables you need for a clean system build with optimal airflow. And, when it's time to replace or upgrade your power supply, it can be removed from your system without interfering with your cabling - the cables stay in place and connect to your new fully-modular Corsair power supply.Incredible EfficiencyWith 90% efficiency at 50% load, the Corsair Professional Series Gold power supply runs quieter, generates minimal excess heat, and saves you money every month. It's earned the 80 Plus Gold seal of approval, your guarantee that you're making the right choice for smart, efficient power delivery.
Details:
Description:
Details:
Detail | Value |
Binding | Personal Computers |
Brand | Corsair |
EAN | 0843591008013 |
Feature | An ultra-quiet double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying fan speed in response to temperature. |
Height | 4 inches |
Length | 10 inches |
Weight | 0.08 pounds |
Width | 6 inches |
Label | Corsair |
List Price | $174.64 |
Manufacturer | Corsair |
Model | CMPSU-750AX |
MPN | CMPSU-750AX |
Package Quantity | 1 |
Product Group | CE |
Product Type Name | SYSTEM_POWER_DEVICE |
Publisher | Corsair |
SKU | DHCMPSU750AXA |
Studio | Corsair |
Title | Corsair Professional Series Gold 750-Watt 80 Plus Gold Certified High-Performance Power Supply - CMPSU-750AX |
UPC | 843591008013 |
Number Of Items | 1 |
Warranty | Seven Years |
