1 - 7 of 7 Posts
Turd Burglar
I know this might be a silly question but, with DDR3 2x2 kits being super cheap I want to buy another set of ram. My question is this: As long as I run both kits at the same speeds and timings are there going to be any issues using my Corsair's with oh say G. Skill, Crucial, or Mushkin?
Pretty much yes, but I usually don't recommend mixing for performance memory. Assuming your Corsair 2x2GB 1600Mhz is rated 9-9-9 1.65V, perhaps pairing with another 1600 9-9-9 1.65V kit (there's a Team kit for cheap) should work just as well, though maybe not for overclocking.
Turd Burglar
My ram is rated at 1600 9-9-9-24 1.8v, so as long as I stay in those lines I'll be alright?
Not many 1600 9-9-9 1.8V kits out there anymore actually. Pairing with a 1.65V kit could cause trouble becaues certain 1.65V ICs start seeing long-term damage at 1.8V (i.e. PSCs). If you could find a similar 1.8V rated kit you'd probably be safe.
Turd Burglar
Well the funny thing is that even though my ram is rated for 1.8 it runs just fine at 1.5 and 1.6. And to me I don't really see a performance boost either way at 1333 or 1600.
Sounds good then, perhaps another 1.65V (if it doesn't suffer from any miscellaneous compatibility issues) kit would work well after all.
Reactions: Kratthew D. Kraids
1 - 7 of 7 Posts
