1 - 20 of 209 Posts
Discussion starter · #1 ·
Originally the TX650 was a SeaSonic S12, and the TX750 was a CWT PSH.
We were told by a Corsair representative that there would be a refresh to the outdated TX series, and would be from SeaSonic and branded as TXv2.
TXV2s appeared on Ecos Consulting's website (80PLUS.org) with the 80+ Bronze cert.
Then we were told that the TX650 would be replaced with a CWT PSHII unit "temporarily" until the TXv2 was launched, and that it would designated "TX650-C"
We kept an eye out, but aside from a brief change in listing on Newegg which was quickly reversed, saw no "TX650-C" units, either in stores, pictures, or in the wild.
Then silence for three months.
A week or two ago an anonymous source demonstrated that the TX750 has been replaced with a CWT PSHII without any change in the packaging or marketing whatsoever, no indication it was a changed model. It's now a PSHII instead of a PSH. It was pulled off the shelf in a store in Taipei.
Original (CWT PSH):
New (CWT PSHII):
As you can see the new TX750 is essentially a GS800 with a non-LED fan and Japanese secondary-side capacitors.
It's probably the same deal with the TX650 and GS700.
The new TX750 will probably have much lower ripple than the original (~60mV vs. 100mV), slightly higher efficiency, and equivalent voltage regulation. The new TX650 will probably have about the same ripple or slightly higher (40-50mV), slightly higher efficiency, and equivalent voltage regulation.
However, build quality on the PSHII units is poorer, with a single layer PCB, weaker transient filter, more failure points due to using six weak +12V rectifiers instead of two powerful ones, and it's rated at 40C instead of 50C. PSHII is also much cheaper to manufacture than PSH or S12.
The new TX units perform about the same or just a bit better; build quality is slightly lower. Changing a product this significantly without alerting anyone, not sending out new review samples, not changing the packaging or anything at all, is dishonest. Even if the change is for the better, or just a sidegrade, this is a major change to the product and not telling anyone is extremely shady. At the very least it should have been mentioned on the JonnyGURU and [H] forums, and new review samples sent out.
Corsair, you're scaring me. I don't want to keep calling you out on crap like this--so STOP it.
Thanks for the heads up and plus rep for you.
but, but, but... Corsair is the best PSU maker ever. This can't be true! [/sarcasm]
Yikes... Check what PSU I have...
I don't want to open it tho lol.
Interesting changes indeed.
We could blame a weak world economy for changes like this. Most companies are looking for every little way to cut production costs. Sucks because we the consumer don't get a say in how things change, and can possibly get the shaft.
yeah but this could also be a dumb move in that less people will buy it because they know corsair is cheaping out on them....
and kinda sad to see a company slowly degrading its product lines....first the C430 and now this BS....make me wonder if there is anything going on with their RAM we haven't heard about
well if mine dies, im not buying another corsair unit....antec will def get my buisness...
Who cares?
I mean seriously. A safe PSU is a safe PSU.
Corsair has been pulling some shifty stuff lately. First the CX line of powersupplies were downgraded, now these ones.
I've always wanted a nice Corsair PSU. But maybe not so much anymore.
Discussion starter · #13 ·
Originally Posted by blackbalt89;11775502
I wonder if my HX-750 is a good unit and not one of these sneaky sneaky PSU swaps.
There's nothing to suggest the HX750 has been changed. Still a CWT DSG last time I saw one opened up.
this is getting pathetic, corsair was praised for quality a few months ago, now they screw around with thier units...let a good thing be a good thing corsair, stop messing around
Discussion starter · #16 ·
CWT DSG is good.
I'm not so much upset over them changing it. What upsets me is the wall of silence and the dishonesty involved.
1.) They initially claimed the new units would be from SeaSonic (they're actually from CWT)
2.) They claimed that it would be a separate series (it isn't)
3.) They claimed that the TX series would be only temporarily changed to PSHII (unsure)
4.) And that the PSHII units and the TX650 in particular would be marked with a -C (never happened)
And then nothing.
Originally Posted by Phaedrus2129;11775814
CWT DSG is good.
And then nothing.
this and they made the GS series, which ive not seen a review of yet (maybe i didnt search hard enough?)
Discussion starter · #18 ·
Gabe Torres reviewed the GS800. It's pretty solid.
i have the 700 >.> wasnt particularly me who bought it, was an early xmas gift
1 - 20 of 209 Posts
