1 - 20 of 41 Posts
Hi guys!
I'm wondering about the quality and acoustics of the Corsair TX650 V2. Very few reviews of this PSU on the net, that is why I'm asking you guys to help me!
The PSU is for my future rig (in my sig) and I have planned to buy the Antec truepower new 650W. However, saw the Corsair, which is about 10€ cheaper. Should I go with the Antec, or should I buy the Corsair?
I appreciate silence and reliability/effiecieny.
Oh, and I'm not going to run sli/xfire (if that make a difference).
Thanks alot for your help!
· Premium Member
The two are on par when it comes to electrical performance.
Originally Posted by Kasp1js;13009472
As far as I know both are made by SeaSonic, but the Corsair has slightly better performance, but it isn't modular.
Also you don't really need 650w for a single 560ti, 500w is more than enough.
Ok, but what if, and when, I will OC both the CPU and the GPU. Is 500W enough then or sould I look at a 550W? Something like a Seasonic S12II-520 Bronze or a Antec High Current Gamer 520W? What do you think?
· Premium Member
· Premium Member
Originally Posted by Track;13009773
Why is everyone forgetting OCZ?
Because of the lingering stigma against them, perhaps. I'd still skip the older StealthXStream and ModXStream units.
· Banned
Okay, look, I understand your "Let's not buy Chinese crap" idea..
But when you start to only recommend top-of-the-line, I take offense.
OCZ is a very capable mid-to-upper-end brand and I have a lot of positive experience with them.
· Premium Member
Read my post again. I only listed series that I know have been problematical in the past, and only the ones that are still readily available.
I have nothing against, say, the StealthXStream II.
Let's not
about my opinions and overall PSU recommendation habits, based solely on a two sentence post.
Take offense? He never recommended anything, just commented on the power supplies that other suggested.
· Banned
Let's not about my opinions and overall PSU recommendation habits, based solely on a two sentence post.
Image was not necessary.
You're the project leader here on the PSU forums. It is not unjust that we fellow enthusiast/experts weigh in on your arch of recommendations.
Like I said, even the ModXtreme should be on your list because it's far beyond the kind of PSU you tell everyone will explode in two hours.
· Premium Member
Well, one can pay $75 for a ModXStream 600W, or $60 for a Rosewill RG-630 that's equal or better in most respects. One could buy a StealthXStream 700W that has a tendency to die (due to incorrect package +12V Schottky whose joints go cold) or one can get something that won't fart and die in one or two years (thankfully the original SXS 700W finally seems to have gone away).
New StealthXStream II series is good. ZX series are good but not priced well. Most of their other stuff... Just not worth mentioning really, most of their new stuff isn't priced well and most of the NOS stuff floating around isn't particularly great.
· Banned
So you're seriously claiming that OCZ PSUs will fart and die?
Great, why don't we all just buy PCP&C from now all and break our piggy banks..
And you're comparing an OCZ to a.. Rosewill?!
I don't even have the strength to argue about this one..
· Premium Member
I believe you're deliberately misinterpreting what I say. I said the StealthXStream 700W used a +12V Schottky diode of an incorrect package. The leads are too big to perfectly fit the solder holes. So the joints go cold and the +12V rail drops to zero, the unit dying silently. It usually takes one to two years for the joints to go, but it happens to a very large percentage of SXS700 units.
And Rosewill has come a long, long way since 2005 when they were using Youngyear and Deer crap. They have many high quality units, including some built by Sirfa, who are one of OCZ's main OEMs in case you didn't know. Sometimes even the same platform as OCZ units.
· Banned
But you have to take a stand somewhere and form a hierarchy.
PCP&C
Silverstone/Corsair
Antec
OCZ
Chinese Crap.
Otherwise, the system breaks.
· Premium Member
80% of all power supplies are made in China, with another 15% or so in Taiwan. Rest in South Korea and India and elsewhere.
And that 80% figure includes most enthusiast power supplies. Heck, the HCP-1200 is made in China, though I'm not sure which lab my ES came out of.
You can't go by brand. You have to go on a unit by unit basis. What are the average electrical characteristics of this unit? What is its build quality like? Who built it? What topology is used? Are there any design flaws?
You can't just say "XX" brand is better than "YY" brand.
Also, PC Power & Cooling is owned by OCZ.
· Banned
But it has to be simplified.
PCP&C is no more, but when you bought a PCP&C PSU you had no doubts about its quality.
Just like you have no doubts that a GTX 580 is better than a GTX 560..
There has to be a definitive, simple way to know/understand the PSU industry instead of memorizing component quality and reading reviews for every model that comes out (most of which don't have reviews).
I mean, unless I can just come to you every time I need to know if a PSU is good or not and inevitably fill your inbox..
The methodology must exist/be created to differentiate between PSUs that are worth buying and PSUs that aren't.
If brands aren't the way - what is?
· Premium Member
if you understand the concept of a psu you can tell whats good,bad or mediocre by just looking inside
there cant be a set standard to class power supplies because the list would be so varied it will just end up confusing everyone
· Premium Member
There is no easy way.
Corsair better than OCZ? Sure, except the StealthXStream II 600W is better than the CX600. But the CX400 is marginally better than the SXSII 400W, but the SXS 400W is marginally better than either. The OCZ Fatal1ty 550W and 750W were just meh, but the Fatal1ty 700W was a very solid unit (built by Impervio).
It isn't like graphics cards or CPUs where you have easy performance metrics and only a handful of manufacturers. There are four x86 CPU manufacturers (Intel, AMD, IBM, Via) and only two matter in the PC space, and there are five GPU manufacturers (Nvidia, AMD, Intel, Matrox, S3) and two of them are completely irrelevant. You have easy benchmarks that anyone can run, and most products are derivatives of the same family of designs.
There are hundreds of PSU manufacturers, each with dozens of designs based on dozens of topologies, and there are hundreds or thousands of brands of components that they can use. And those hundreds of OEMs distribute through more hundreds of resale brands.
PSUs aren't like other things in this hobby. It's a complicated subject, and one that can't be boiled down to a handful of easy numbers.
1 - 20 of 41 Posts
