1 - 17 of 17 Posts
Hi all,
I wanted to share my small victory.
I was able to get my DDR400 Corsair XMS 3200CPT Ram to DDR 500.
I had to up the voltage to 2.8, and I loosened up the timings:
2.5
Command rate of 2T
I didn't think I would ever get it that high. Sweet.
Not bad, that's TCCD right?
That's pretty damn good. I have mine at 250 as well with timing of 1T- 2.5-3-3-5 at 2.9V. You should be able to tighten it up some but maybe not. That's still good though. I love Corsair!!
Discussion Starter #5
I thought I was going the Cheap route when I got this stuff. I'm pleasantly surprised.
Discussion Starter #6
How can I tell if its TCCD?
and . . .
What's TCCD? I'm still kinda new to Overclocking.
I have heard nothing but good stuff about Corsair. I had OCZ before this and I hated it. It is rock solid mem.
and . . .
TCCD is a kind of RAM chip made by Samsung that is known to be a great overclocker with relatively low voltage (compared to BH-5). You would have to look under the heatspreader to find out, but if you post the model number, ex: "TWIN2X1024A-6400", I will look it up and we will see.
Discussion Starter #9
Here you go:
Corsair XMS Platinum CMX512x2
XMS3202C2PP v5.2
0546126-0
I believe that is correct.
Thanks,
OK, they aren't TCCD, but ProMoss-5 IC's. I have never heard of these, I guess they aren't bad though.
Reactions: The_Snyper
Discussion Starter #11
Thanks again, I appreciate your time. Too bad about the TCCD, but I'm still giddy about leaving the RAM divider in the dust.
Rep+
I am still not 100% on that, but the v5.1 is ProMoss-5 rev. A, so I bet the v5.2 is just a different revision of the ProMoss-5.
Nice OC, see if you can get a little more!
Discussion Starter #13
I'm crashing now in Battlefield 2 at those settings. The Game launches fine, bu about a minute in, the system locks.
Any thoughts on the Max Voltage? I thought the stock was 2.7 and safe max was around 2.9.
I would not go over 3v just for lack of knowledge about those chips. You could also try looser timings. Like 2.5-4-4-8 or 3-3-3-8.
Discussion Starter #15
I'll try 2.9 with current settings, then go looser, if necessary. I would really like to avoid running on anything other than a 1:1 divider.
Overclock Failed...
I have the v5.2, RyGuy, and yes they are Promos -5 A's...
And I must say, I am seriously happy to hear how well you've done with them, The_Snyper! Especially since I'm about to OC my sticks.
Speaking of which, once you find a BF2 (if not SuperPi) stable configuration, can you post it please? It'll help me know how high/far/hard I can push my sticks. Thanks man!
1 - 17 of 17 Posts
