Originally Posted by pauldovi the corsair is better, but not worth the extra cost. Go with the OCZ... |
Originally Posted by Remonster Yeah, as long as it isn't any problem to get the 2GB (not enough RAM slots, price etc.) 2GB is certainly beneficial even if you don't play F.E.A.R. and BF2 and other memory hungry games, you can certainly run a smaller page file or even no pagefile at all. |
Originally Posted by binary_sandman No they aren't CORSAIR DUAL-DATA-RATE HAVE LOWER CAS LATENCY; And are more reliable you don't like them cause you can't afford Corsair |
Originally Posted by binary_sandman Let's break it down for you script_kiddies The cas Latency is like a 555 timing IC it times all of your operations and shifts data around mostly binary text; LOWER CAS LATENCY = programs opening faster and better run time on games; Also smaller time you have to wait On the other hand the operating frequency of the ram lets say 400 MHz This is like talking to your cpu(central-processing-unit) higher frequency=your cpu will be happy cause of compatibility compared to 200mhz __________________________________________________ _______* Personally I would go with the lower CAS LATENCY timing is everything don't worry about operating frequency but that's my opinion you need to decide |
Originally Posted by pauldovi This is not a memory fighting forum, we are helping a guy pick out some RAM, not a place for you to scrable... KNOCK IT OFF! |
Originally Posted by binary_sandman That’s cool we have the same case NZXT LEXA. It is like the most sexist case on the market right now. |
