Cosmos S mod for better cable management & New WC setup for GPU new pics(5-20-09)
43301 222
**Update*** 5-5-09
I will be adding a second loop for my GPU and modding(if I can) my case to improve cable management.
Also, I will be installing my new Rampage Extreme. So I will be posting some new pics for you guys soon. Stay tuned!
3-11-09
**Cosmos S little mod for 38mm fans & new WC setup build log done!(new pics 3/20/09)**
Hi guys and gals,
After reading though stuff and from your guy's big help, I decided to put together some WC parts and start my custom set up. I will be modding my Cosmos S to fit some 38mm fans in the fan compartment on top(at least will try, might need your guys's help) and setting up my WC setup. I will be taking pics to give you guys back the favor
. I really appreciate all the help
More pics will follow as I go with the setup, so there will be more pics to come
My parts came in today from Jabtech and here is the pic:
1 - 20 of 223 Posts
Discussion Starter · #2 ·
Looking good so far! Nice start.
Thanks!!
Where is the best place to mount the pump and res in a Cosmos S?
Discussion Starter · #6 ·
I have to call it a night since its already late and I have to wake up in four hours to go to work. Here are some pics that I took a while ago...I was not able to make a lot of progress due to my lack of preparation. I had to run to my local store 3 times to get the stuff I need and I couldnt decide where to mount the pump and the res in my case..anyway here are the pics:
This would serve as my reducer since that fuzion barbs are 3/8" OD and my tubing is 7/16" ID
With the CPU water block attached:
With the reducer and CPU block in the case:
Black Ice GTX 360 money shot!!
Needs some more modding to align screw holes of the Ultra KaZe to the case:
GTX 360 installed on top of COsmos S:
Everything mounted except for the res:
Front view:
Here's how it looks without the top mesh...this would be the spot for three Ultra Kazes doing pull config:
I hope you guys like it..Please let me know if you guys have some suggestion. I hope its fine to post this much pics. Please let me know if I am violating some rules.. Thanks guys..
I will continue the build tomorrow after work..See Yah!!
Discussion Starter · #9 ·
Originally Posted by Hellraiser1981 View Post
Keep up the good work & keep them pics coming
Will do!! I will continue the setup today when I get home from work..
Thank you !!
Originally Posted by ChielScape View Post
this pic made me trip balls yo
Haha..I know that pic turned out to be a little weird.
By the way guys, is it alright that the pics I am posting have those crap links at the bottom? I noticed it and I thought its because I am using a free file hosting site.
looking good mate!
keep up the good work!
+ love
Reactions: unleaded91
Do you have room for the pump on the floor of your case? I like to keep it at the lowest point and my res above the pump, right over it somewhere.
What res are you using? I didn't see it in the pic's. If your going to use a t-line put it right before the pumps inlet.
Discussion Starter · #13 ·
thanks!
I am using the Swiftech MCRES Micro v2.. I mounted the pump right on the bottom fan slot(slot behind the PSU) of the Cosmos S and I am planning on mounting it right above it as you said.
Can you please help me with the best loop arrangement?
I will be WC'ng my CPU and NB. Thanks..
Like this:
Res-pump-rad-cpu-nb
^^^Yup. Thats the way I like to run mine to. The most important part is the keep the res right before the pump.
Their goes my friend!!!
Thanks..
haha
Well ira-k teached me, so thank him
Discussion Starter · #18 ·
Okay will do for sure!!..
The flow of the D5 starts from the top barb right? So I should start from the outlet of the res to the side barb of the D5(inlet) then up to the rad and so on right?
Thanks!!
I know you didnt talk to me, but you are correct
1 - 20 of 223 Posts
