1 - 17 of 17 Posts
I'm stripping my sig rig down tomorrow & doing some cable mangement then having the inside (alloy) powder coated, I'm not sure what colour to have.
I'll be having Acid green feser fluid & I'm changing all my 120mm fans for green leds.
So what colour will set this off?
Tell me what you all think
Originally Posted by Izvire View Post
Black outside&Green insides?
+1 that would look awesome on a cosmos. How much does it cost on average to powder coat a case? In usd if you can.
In the uk, well exeter were I live I was quoted £25 for the powder coating.
I'll be keeping the outside of the case standard for the moment, what do you think to orange for the inside? Orange & green?
Seems like the colors would clash a bit, I personally would stick with just green. Unless you are into the whole 80's neon thing
Discussion Starter · #6 ·
Ok, thanks. Thinking of putting a few uv light in as well.
That would look awesome. Make sure a lot of your components are UV reactive
Discussion Starter · #9 ·
Originally Posted by noahmateen1234 View Post
I say black inside and green outside. That way the inside will accent the outside.
jw is this gonna be like grass green or neon green?
oh and get that techflex ogre sleeving and sleeve all the cables.
Maybe grass green.
How about yellow inside?
That's a really good price for powder coating, you got a good deal there.
Who is doing it for you exactly?
Discussion Starter · #11 ·
They are called "1ST CHOICE FINISHES" in Exeter, they showed me around their work shop, they have a good setup there, also there work shop is really clean if you know what I mean.
Your finish may not withstand the temps that the inside will have to be cured at. Just want to let you know that.
And, look into a color called Psyco Lime. I did a 4 wheeler frame in that and it looked pretty good.
lol i'm still confused!
The outside of the Cosmos S is plastic so it's a fairly safe assumption that he'll strip the case down before handing it over to be coated, the interior chassis is all aluminium apart from 2 parts which the handles screw into, I think they're chromed or some other form of electro-plating.
PS: I'm well aware of the curing times for coating, check my sig.
Discussion Starter · #17 ·
Your the man marcus! Sorry to sound cheesy but I'm loving your work! I've read through all your threads on here & wcuk which I've used for parts & will use again. It was just a shame that ur powder coating price's are a bit high.
But If the finish isn't good enough I will be in touch, if thats ok?
Anyway check out my project cosmos in my sig.
1 - 17 of 17 Posts
