Per the ASRock Xtreme Tuning Utility thing.....chassis fan 1 (my Cougar fan) is running at 1K RPM. I have it set to level 1 with a target chassis temp of 50. The current chassis temp is 30 so it shouldnt be ramped up at all.
Is this a function of the mobo not letting it go that low? or is the fan the culprit?
I plan on running these off a Giled splitter, which will be hooked to the CPU1 fan header (the CPU fans have no problem running at 7-something RPM right now.....Silver Arrow cooler so TY-140 and TY-150). I suppose I could connect them to a lower voltage side of a Molex, but I wanted to see if the fan is the issue or if the mobo will never let the fan run at lowest RPM.
Any ideas? The only reason Im asking is because the Cougar seems to be the loudest fan in my case......its mounted in front intake position of my HAF-912, and I think Im just hearing it pull air thru the mesh on the case. Lowering the RPM should lower that noise (for normal use, anyway).
Thanks in advance.
-Chris
Thanks in advance.
-Chris
