1 - 3 of 3 Posts
I was wondering if for my first lil watercooling build ever and to save some cash if i could just use the Corsair H60 Water cooling system, but modify it a lil bit. I would get rid of the tubing it comes with. Buy another 120mm Radiator for the Front and use the one that come with is to use in the rear of the case. And then i would buy new fans, one for each radiator. and i would add a reservoir in the loop somewhere and buy new tubing to make it all match... Would this work or just be a complete failure? I have a Phenom x2 565 3.4ghz Unlocked and overclocked to a Phenom x4 970z 4.0GHz and i want to watercool.
more chroma!
I doubt the pump would be enough for two rads and a res.
1 - 3 of 3 Posts
