1 - 18 of 18 Posts
I would not advise OC'ing mobile processors. I have a Turion and it gets kinda warm. You could OC it, but it would get HOT.
well can u tell me the steps in overclocking it i have back up motherboards and cpus so if it burns out or something i got extra
Normally you would increase the FSB by small increments, also increasing the voltage. But in manufacturer laptops this is usually disabled unless noted otherwise.
Super Moderator
If it's a laptop, or a pre-built machine, its not worth the hassle. You won't get very much at all out of it. And you'd have to use software overclocking tools, which run a VERY high risk of data corruption and damage to equipment.
I will advise against it also, not worth the risk but if you must you can try setfsb.
As others said you better dont go for oc.Btw you dont get much from Sempron Mobile at all.
Discussion Starter #8
well i overclocked my gpu and my sempron 2.4GHz~ and it runs a bit faster u.u and i dont get how u guys say it runs hotter then turion is cooler way cooler my turion be burning my sscreen and making my touch pad so hot i cant touch it
I don't think anyone said it runs hotter than Turions. But the Turions do burn up, I have one in my laptop. Single core will almost always run hotter than more cores, under the same circumstances. (Varies with clock speed, Manufacturer tech, ect ect.)
^this its not worth the risk even if you do get higher clocks it may not be 100% stable
Originally Posted by Neko_X
doesnt matter really i already overclocked my sempron
hmmmmm did you put it under load to see if your load temps are ok depends on what your using it for hmmmmmmm
The Computer Guy
im gonna buy this http://www.bestbuy.com/site/Compaq+-...&skuId=1272095
and when i do i wanna overclock it D:
if u can find oc software,because those bios settings are locked.plus you run the risk of burning it up.but,good luck with that.
1 - 18 of 18 Posts
