1 - 9 of 9 Posts
I let my mobo decide the voltage for some crucial ballistix and it set it to 1.6v<br />
Could that cause errors in memtest86?
Retired
If the voltage on your ram is set to low, then yes, ofcourse it can cause errors. It would be the same thing as undervolting a CPU then running prime95. Arent those high voltage DIMM's? Let me go check. I would suggest setting it at what the Manufacture suggests. That ram should be running at 2.8 volts as seen here: <a href="http://www.crucial.com/ballistix/store/listmodule.asp" target="_blank">http://www.crucial.com/ballistix/store/listmodule.asp</a> . Check out the bottom of the page.
Reactions: stormlobster
LOL LOL LOL LOL LOL.<br />
<br />
Thats low for even DDR2. Try putting it to 2.8v
very likely yes. Check what the stock voltage of these sticks is. 1.6V seems very low to me.
Discussion Starter #5
OH CRAP I MEANT 2.6v! I know its supposed to run at 2.8 but it runs really hot at that temp so i thought that 2.6 couldn't hurt. But if it causes it to crap out, ill up it
Delete me.
Discussion Starter #7
be back in a few mins ill run memtest now
Run 2.8V. It isn't rated for that voltage for nothing. Rig a fan for some extra airflow if you're worried.<br />
<br />
Deleted gonX... <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" />
Discussion Starter #9
i upped the voltage and i ran memtest but i still got errors. I got 68% through the first complete pass and then it gave up at 738 errors!I doesn't matter though, I've got 2gb crucial ballistix tracers on the way here anyways!<img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" />
1 - 9 of 9 Posts
