1 - 6 of 6 Posts
hi guys, i have been palying Sims 2 Pets, and it is jumping now and then and its freezes for about 4 sec.<br>
could it be my RAM, i only have 512MB DIMM DRR. i hope to get 1GB if it is my RAM making it jumping ect.<br><br>
Thanks for your help!
There could be several other issues that are causing your game to flip out that way.<br>
IMO, it could be your system overall, I mean, look at the CPU's speed and video card, how much RAM btw? Have you cleaned up your HDD? Run a full scan for fixing bad sectors? Defrag? Spyware removal? Virus removal? Registry currupted? PSU flaking? CPU's overheating? and so on................................
and heat
my brothers run Sims 2 @ 1440x900 with full settings on a 5200 and 256 o Ram, however you will notice a very small amount of lagg when chaning menus.<br><br>
However runs great with 512mb, and that only with the P4 running at 1.9Ghz<br><br>
So its not your system at all.<br><br>
HEAT, DEFRAG etc
Discussion Starter #5
ok i have defraged my HDD, just about to play so i will let you know!
Discussion Starter #6
runs ok still jumpy but alot beter ty~!
1 - 6 of 6 Posts
