Could this cause problems?
264 Views 2 Replies 2 Participants Last post by  Bouncer
Been having problems overclocking my CPU and I have been reading up on some ram settings in the amd memory forums.
My ram:
Kingston hyper-x PC-6400
[email protected]
[email protected]
If I did not add any voltage to the ram and ran it [email protected] would this cause blue screens/freeze?
Also If I ran:
CPU @ 2700 and Ram @ 800 would this also cause Blue Screens/Freeze if trying to OC the CPU?
Basically I am asking if my ram could be the cause of some of my Blue Screens/freezes because of the settings.
1 - 3 of 3 Posts
Most likely, as the ram runs tighter timings at 667 (probably 4-4-4-15) as opposed to 5-5-5-15 that 800Mhz runs. If you loosened the timings to 5-5-5-15 at 800Mhz, you might be fine at 1.8v, but i'd up the volts a little to be safe
RAM is one of the main causes for BSOD's from my experience. Try upping the RAM volts a bit to see if that helps
I added .1V to the ram. So far so good, no problems.
I have also OC to 920Mhz
[email protected]
[email protected]
[email protected]
[email protected]
I tried going to
[email protected]
[email protected]
[email protected]
[email protected]
but it BSOD on me after 20 or so minutes.
1 - 3 of 3 Posts
