Safe voltages would be anything below 1.5V...this is safe.
3.8 should take around 1.5v give or take a few volts.
Sometimes it does disable cool and quiet and sometimes it works...I dont think there is any explanation as to when it works and when it does not.
Yes you can hot key them with a program like AOD, but software overclocking tends to be a bit more unstable than bios overclocking for me.
Ram timings will be important. So first start with the ram and get that upto the rated timings and latencies. Then look at overclocking the NB using a combination of the multi and fsb steps for the last part, and then finally the cpu, with multi and then fsb steps for the last part.
For a 3.8 u may not need to use the fsb steps at all. Just use the multis.
