Couple of questions regarding [email protected]
225 Views 6 Replies 3 Participants Last post by  Nautilus
Guys i've been folding for some time but still don't know some things.Please enlighten me about these:
-What does exactly PassKey do?
-What happens if i type it wrong and folding for some time like that, waste points? (I think i did that
And can someone help to solve my Unknown PPD problem?
As you can see below, [email protected] recognizes my GPU client well but in CPU Client section i get "o.oo*" PPD and Unknown Credit.Why is that? What can i do to solve it? (Btw i'm using x86 CPU system tray client not console)
1 - 7 of 7 Posts
Passkey is a specific key provided by stanford to make sure that no one falsely folds in your name. If you typed the passkey in wrong when configuring your client it will tell you.
Here is the passkey FAQ on their website. Link
In FahMon, got to Tools->Download New Projects. If that doesn't fix it, then shut down and restart FahMon.
Restart the client itself then.
If that does not work, then just watch the client and see if it is actually running and doing work.
well i guess the problem solved itself. after finding no solution, i went to bed. the first thing when switched my monitor on was CPU client generating 233PPD
1 - 7 of 7 Posts
