1 - 4 of 4 Posts
What does it mean to run your memory 1/1? For example, if my fsb was 200, would my memory have to run at ddr400 to be 1/1? Also, kind of off topic but, could a pencil mod on an nvidia cause random reboots?
Correct on the RAM.<br>
DDR400 runs at 200MHz, if the CPUs default FSB is 200MHz it's 1:1<br>
The pencil trick, if you are OCing to the point of the voltage increase being a factor, then yes if the pencil mod is not providing a stable increase the OC will crash out!
k thanx dude
Also, I don't think it matters if you run 1:1 on AMD like it does for Intel.
1 - 4 of 4 Posts
