1 - 20 of 22 Posts
It's not know for it's OCing capabilities. I'm assuming your asking for someone else though since you already have a nice cpu. If so, then it depends on their price bracket and what kind of performance they're expecting. I'm assuming your from the UK, but for example in the states, that Q8400 goes for $167.99 on newegg.com. The Q9550 goes for $179.99 at microcenter. In that casethe Q8400 is not a good deal at all. Hope this helps.
Testing...
A lot of people recommend the Q6600 over the Q8400.
A Q6600 can be had for very cheap second hand.
It's kind of hit and miss with the Q6600s. G0s usually OC pretty well, but others are not so great. Gaming is fine even on stock clocks. Overall, it's a great choice.
Originally Posted by issy View Post
thanks guys just found it for £95 so jumped in and got that bad boy
Great.
Your sister will love it.
yeah man get a used Q6600. mine does 3.8 ghz on water. I currently have it in my step-sons computer @ 3.4ghz with a gtx 260 SC and the computer aint no punk either!!(he's 13)
I have an 8400 and got it to 3.2ghz easily but any higher and it becomes hard, excellent cpu for video encoding and I can play all my games with it. If you can get it cheap then i would deffinitly get it.
Discussion Starter · #16 ·
oo now im thinking everything i just said except a gtx260 sc as they are cheap as chips at the moment and it can still pretty much run everything + if anything dont run maxed out ill just play it on my main rig
Testing...
i may just pick up one for myself as ive been meaning to build a intel machine for awhile (as a spare)
think ill go
q6600
gtx275
4gb
750gb hdd
win 7
No sense in spending money on 775 when 1136 can be had for the same price.
1 - 20 of 22 Posts
