Rasa is great for budget builds otherwise the koolance 370 and EK HF Supreme are your other best choices. You can snag a EK HF Supreme Acetal Finish for $72ish but I woul probably go with the Rasa if you wanna stay on the low end its only like a 1C difference anyway which to some is worth the extra 20-30$.
Temp difference is less than 1C as stated earlier (it's really REALLY close) and if you are under a budget then there is no reason not to get the Rasa. Less than 1C will not affect overclocking or performance whatsoever and the flow is just fine through the block.
1 - 8 of 8 Posts
