I just installed the cpu fan like some people told me with a heat sink.
offcourse i took out the power first and then changed it.
when i reboot i get error saying:
CPU changed or unusable - please check CPU Soft menu.
F1 to continue Del to setup.
so if i do DEL to setup and then exit with no changes it boots and shuts itself down after 2 seconds.
if i press F1 so it loads windows just fine.
so what is the problem here exactly?
Also im using nortwood p4 3.0ghz and my idle temp islike 41 C, but im using a good fan with arctic silver i dont think this should be like this.
i hope i didnt apply the as 5 wrong. what i did was just put it on the cpu chip and smear it all over it with a glove. but i mean it wasnt all the same size but it was covered for sure.... but now i had to take it apart to put the heat sensor in and it didnt look so good i could see some bare spots or maybe just a very very thin layer of as 5..
so the idle temps too high i dont know what i can do im giving up hope.. you guys can help?
