1 - 9 of 9 Posts
Hi !
I was wondering what of the following settings are best turned on or off and why:
-GART Error reporting
-Microcode Updation
-Secure Virtual Machine Mode
-Acpi SRAT table
-CPU prefetching
I keep C&Q and C1E disabled.
Would you kindly post your system specs so we could help you better?
-Microcode Updation
-Acpi SRAT table
-CPU prefetching
Leave all of these on.
If you're not running a virtual machine, you can turn this off.
CnQ should remain on if not malfunctioning, it doesn't even affect OCs. If you can confirm it is malfunctioning, then turn it off.
Discussion Starter · #9 ·
I was using C&Q since my Athlon XP 3200+
But it stopped slowing down my CPU when idle (on this system) so I just turned it off...
1 - 9 of 9 Posts
