1 - 11 of 11 Posts
what should a prescott 478pin 3.2 gh w/ht core volt be?
i am getting a reading of 1.376v is this to high? if its to high how can i lower it.
no, thats about what the stock levels are. you can safely go to 1.5v. 1.525 max if your cooling can support the temps.
Actually the max limit you would want is 1.7 (as told by Taeric). I have my Pentium 4 running at 1.57volts.
1.7 volts works just fine with Northwoods, but you don't want to exceed 1.525 volts on Prescotts unless you have really good cooling.
Originally Posted by Paulie
heya...got a [email protected] and i've just oc'd it to 3500(external freq 171,vcore 1,600) wut are my odds? it's booting normally and i see no problems 4 now....
As long as your load temperature stays under 55C, you're in good shape. With good temps, you still have another 0.1 volts, which can make a big difference.
Administrator
It is best to start a new thread for questions
As for your answer at that voltage there is a possibility that it will operate, however I would expect the voltage to be nearer to 1.7v for it to be totally stable. Run Prime95 to check that it is fully stable
I got from 2.66Ghz to 3.5 with stock voltage but even at 3.3Ghz i had to add a little vcore for it to be stable, its now running like stock (but faster
1 - 11 of 11 Posts
