1 - 3 of 3 Posts
Hi everyone,
Well for the better part of 2 weeks CPU folding does not work. I was using the Advanced client for multi cores and it had been flawless. Well 2 weeks ago my computer restarted from an update. When I clicked on my CPU icon the CMD window popped up for a milisecond then nothing. So I reinstalled it and tried again. Same issue. I noticed on the Stanford site that "technically" the date has passed for the "beta" so I went to the "normal" client.
I installed that and the same thing happens. SO for 2 weeks no SMP folding for me.
Anyone have any ideas as to what is happening.
Thanks so much!
Originally Posted by FtW 420 View Post
The client expired a few weeks ago, download the new v6.24 executable from [email protected] you should be good to go..
FTW 420,
I cannot find the v6.24 for windows Vista 64. I only see it for Linux which I am not running. Any other suggestions?????
Regards,
Ok....my bad....just found it on the site...just had to dig a bit deeper...Thanks!
1 - 3 of 3 Posts
