1 - 9 of 9 Posts
On my Athlon 64 4000+ 9n overclocked 600mhz to 3.0, I would like to see if emplying CPU frequency scaling could be nice. Any thoughts?
same CPU here, only with a much worse overclock - what are you using?
I was using 250*11, and i've seen water getting the "big 3", but your the first i've seen using air - are you just lucky, or what?
BTW, if that is a Linus app for the = of CnQ, most have difficulties combining CnQ with OCing and avoid it.
Discussion Starter #5
I can set up cpu freq on linux no problem, I was wondering if there for more general things in terms of cpufreq + ocing that I should look out for.
As far as my overclock goes, I use a zalman 9500, asus a8ve, and a voltage of 1.4875.
I hit 250x12 with my newark 3700 on air
(way back in the day)
1 - 9 of 9 Posts
