1 - 3 of 3 Posts
I have bought a pentium 4 cpu 3.0ghz with ht and 800fsb but have just relised my motherboard`s (Asus p4s8x-x) max fsb is 533fsb will the cpu run and if so will it run right or damage anything.
It might just underclock since your stock FSB is only 133MHz and the Prescott you have is more than likely a 200MHz. You can try clocking the FSB up to 200MHz to get your stock speed.
1 - 3 of 3 Posts
