1 - 20 of 27 Posts
my cpu died. i need to get a replacement. i have a Gigabyte GA-Z77X-UD3H board, socket 1155 so i need something to replace the dead cpu. can anyone point me in the right direction. i need something cheap (or free) as i am currently out of work (covid :/ ) thanks in advance. Russell.
i see some Intel cpus on Ebay. are any of those what i need? https://www.ebay.co.uk/itm/Intel-Core-CPU-s-Select-i3-i5-or-i7-Models-sockets-lga1155-1151-1150-LOT/143652321330?hash=item2172587832:g:Ox4AAOSwEYNfBb~s&LH_BIN=1
somewhere on ocn
What was the cpu that died?
Any 2nd gen (Sandy Bridge) or preferably 3rd gen(Ivy Bridge) intel will work in your board.
Discussion Starter #3 (Edited)
thanks for reply. i don't know what it was, (lapped the info off it) and my memory doesn't want to help me. i just need something that will get my PC up and running again. i seem to have option of i3, i5, i7 . but no idea where to start. i can get an i3 for £10, and just try it. but i would prefer to get what i need rather than trial 7 error, which could take time and waste money
would this do it? https://www.ebay.co.uk/itm/Intel-2-60-GHz-2M-Cache-G1610-Celeron-Processor-LGA1155-Ivy-Bridge-CPU/124281746862?_trkparms=ispr=1&hash=item1cefc4f5ae:g:kkkAAOSwx9xe3Ovf&amdata=enc:AQAFAAACYBaobrjLl8XobRIiIML1V4Imu%2Fn%2BzU5L90Z278x5ickkp2NA0WuhQytmt4dbStg00FXjGKEHFX9BLnS8c13nkqrGPSCmefDAUPFhNWYtynTmrxTw%2BxpFkai2kqRWAad4BqZGfmAdU54IRNoOVSY76O3I96dwuL5CZauC4iPLP8pgibJe%2BnS01cpJ7mkKykbzW8HcxonD2NQWfGNnPCFGHtaZFQX50owm9QHoxUnTOHNP7HCQrAW9FhSi4xEAMZBFGU9ZazOEw094h0ggmQEDw4e1VNIg4rb2Qz8vA7J76Pzo%2FRZFQWZXoNMboeNJmC6Panl9hk7m9TgeyGG%2Fp7Y9PSsx5O%2F4bV1rkaD8fx2T%2BSl%2BHCPeQHJnRsmKndSuOF0s76VbVHIl08tQBufHdiXHWGL1wfwOqhvF%2BPodQkDeu4XGSOdRbdD5HfQmf9LljuYbasxKzV1m4I%2FCF4iLSw%2BfNzp1O7GRfCkRhnnHIOzXjCDrhurbuDw7A7ix3RBhvIZ7T%2Bqpi2bqqMK01JTeoq5NY1vi77JQA8STeEJTV3enhzDI09QiDIzSKrzHATmJzj%2BDfOBQo4YvTjy61THYRiKnEr4KgzDZ8Ztw9mVndtZpyGXeP1MR3Fr%2BUD8ewEqLnuhtNasyr4caFq9NyYlhCzL91h5lhgOtD81vDfi1Dfy3aLPRNaWRq3fFVELuQEbsXXt1m1BUXrv4bPMGzgcYIiC1FNQjxWBfK4jBR%2BfM9w7yM68K6ajNPGYltjf%2BT8VhAWWQb7WMp72jHUk5Ip7DV7Xx%2BMEYRv1IQnx%2BV%2BkMFakLl44L|cksum:124281746862eb360e1fadd04af6b6c392087839cd09|ampid:PL_CLK|clp:2334524&LH_BIN=1
9 Cans of Ravioli
Graphics Junkie
Do you really need a list of CPUs? Its 2nd or 3rd gen CPUs...
I would go for a 2600K on ebay, they overclock much better than the 3770K and are cheaper.
https://www.ebay.com/itm/Intel-Core-i7-2600K-SR00C-3-4GHz-Quad-Core-LGA-1155-CPU-Processor-km/402187469135?hash=item5da43dc14f:g:wJ4AAOSwfAhefgtg
Edit: here is the tea and crumpet version https://www.ebay.co.uk/itm/Intel-Core-i7-2600K-3-4-GHz-Quad-Core-Processor/402347957317?hash=item5dadce9c45:g:0xEAAOSwxBJfJwfP&LH_BIN=1
How do you know your CPU died and not the motherboard or something else? I would assume that if you are asking what CPU to get then your testing methodology might not be very thorough.
Discussion Starter #6
Graphics Junkie
Discussion Starter #8
oh hang on, i see a pattern forming, lol
maybe this is it ?
Graphics Junkie
maybe this is it ?
Why are you looking at the worst possible options? I already gave you a link to a great option. Did you even notice?
Discussion Starter #10
UltraMega - i got it tested locally. result was CPU-dead, 1 x Ram stick corrupt, O.S. corrupt. everything else works.
Discussion Starter #11
UltraMega, yes seems a good option, but i'm skint mate, been out of work since march (covid) :/
Graphics Junkie
Then just get a 2600K. It will work and its the best option.
or a 2500K if you're on a budget.
I assume you want this PC to be able to do more than just facebook right? If you play games on it the 2600K is your best option for sure.
Reactions: bicolormoth
Discussion Starter #13
Discussion Starter #14
Thanks all for replies and suggestions, i think i know what i need now. you guys are awesome, as always (Y)
Graphics Junkie
That will definitely work but if you can afford to get something with at least 8 threads it will make a big difference in how much longer it can keep up with newer games.
This would be your cheapest option for an 8 thread CPU I think.
https://www.ebay.co.uk/itm/Intel-Core-i7-2600-3-4-GHz-Quad-Core-CM8062300834302-Processor-31-7-J16/264818890403?hash=item3da86f96a3:g:jwoAAOSwLNtfJDnt&LH_BIN=1
Graphics Junkie
Discussion Starter #17
well UltraMega, would you even believe it, lol. i just found the box for my old CPU -
Graphics Junkie
Old spare CPU? So you already have a 2500k? Nice. Let us know if you need help overclocking it.
9 Cans of Ravioli
take the time to read, it's useful occasionally :laughings
Discussion Starter #20
no, this is the box from the cpu that is now broken. so at least i know which type it was. but i cant afford a direct replacement. i'll try to get an i3 for as little as possible. just to get my PC started up again.
1 - 20 of 27 Posts
