Wait you have a stock 965 running at 4.2ghz via multiplyer ? Also I'd recommend using Prime95 for stability testing although AMD Overdrive serves it's purpose the prime95 works for both Intel and AMD.
NO, that is not supposed to happen unless you are seriously stressing out your CPU to find out it's breaking point. AMD Suggests that no 965 should run over 65C either idle or under load. I would try re-seating your CPU Heatsync and possibly reapply a new layer of thermal compound.
