I changed the FSB in BIOS from 200 to 210 and when I saved and tried to boot into windows my screen went onto stand-by and the computer kept resetting... Finally I was able to get back into BIOS... I changed the clock back to 200 and had no problems after that... So then I tried to use the AI Overcharge option in BIOS and put it at 5% OC and I had the same problem... But, I want to OC the CPU... so I was wondering what else I should try or if there is any other adjustments I should make?? Any input would be great!!! Thanks!!
