1 - 18 of 18 Posts
Hi everyone.This is my first post on this fabulous site. I have read that ocing a cpu shortens its life.Is this because of the extra heat,or are there other factors.In other words if i oc my cpu but keep the temps down will it have a normal life expectancy?Also, is there such a thing as running a cpu to cool? One last question.What do you guys think of my oc settings?(see atachment)
Overclockiit
Nice Overclock, and welcome to the forums, yes overclocking can/will shorten the life of a cpu and heat is the number 1 cause of this,but like you said if you keep things cool you should get a normal lifespan out of it, and as far as can a computer be to cool no cooler is always better, but thats just my 2 cents im sure everyone will have a comment on it
Ive heard that cpus start to run less efficiantly under 30C
but thats just what ive heard..........and ive heard alot
When it comes to semiconductors, colder is better because the colder they get the more conductive they become. That's directly related to why sub-ambient and sub-freezing cooling yeilds better overclocking, the colder the core gets, the more efficently it operates at a given voltage and will be able to run faster. Overclocking will shorten the lifespan of your processor, but if you keep things within reason it'll still run for probably 8+ years and if you keep your processor that long, you have other problems to worry about
Both heat and voltage can kill a processor. When you say "normal life expectancy", that is a very broad phrase. Current CPU's are designed to operate for 10 years within specified thermal specs. Will you get that much use out of it? Heck no. Does overclocking reduce life of a chip? In a nutshell, yes, it does. In most cases, if temps and voltages are kept at "decent" levels, then the chip would probably last 6-7 years. When you go extreme, that shortens greatly. It all depends on keeping the voltage within reasonable limits, while keeping it cool at the same time.
Can you get a cpu too cold? Theoretically-yes. In all reality-no. If you could get a cpu to absolute zero, then all molecular movement would stop, but we are unable to achieve a temperature that cold. Scientists have come close, but not quite. I believe that an engineer once put a cpu to about 4 Kelvin, and it stopped working, but the equipment needed for that for just outrageous. The most extreme overclockers in the world use either LN2 or triple cascade phase change systems. This is very extreme and they get their processors down to under 100C! For more info on this, click here and here. Sorry to ramble, but I hope that helps!
Reactions: DeathONator
Welcome, I think what Lando meant was - Yes. J/K Lando
LOL, :swearing: LOL And BTW, Welcome BradMan!
Originally Posted by aznchowboy650
Does abit ic7 max3 have that screen shot feature too?
You take a screenshot by hitting the key on your keyboard that says "PrintScreen/SysRq" Then open Paint, and click on edit-->paste. Save as jpeg, and your done.
Originally Posted by ThE_GeNeRaL
what is that program that bradman is using to shoe his oc?
Asus AI booster.
does abit have a abit ai booster?
Abit has OC guru or something like that. I am not sure about DFI. Be advised though, it is recommended to overclock from bios, and not Windows. It seems to be more stable, and causes less conflict.
Discussion Starter · #18 ·
Asus AI Booster came on a disk of utilities with my mobo.Lando I have also heard (read guides on this site) it is better to oc in your bios,but I have found Ai Booster to be more stable.When I originally tried to oc in bios it would work for small ocs but when I would try to oc 10% or more my start up screen would come up and say "overclock failed.return to set up and revert settings". So I tried with AI Booster,10% at first which gave me a speed of around 3300 MHz.Seemed stable, ran this setting for about a week with no problems at all.Then about 4 days ago i bumped it up to 15% still stable no problems.
1 - 18 of 18 Posts
