CPU louder than rock concert
470 6
ok. i have a problem! my cpu is being annoyingly loud when i play WoW after five minutes. its fan runs 6000 rpm and its stable around 40c to 42c. The thing is i believe its not a very high temperatute for a cpu but i am not sure why it makes this horrible sound. Could it be my psu? do i need more power? i am getting game crashes once in a while and disconnects from the internet. my +12v is at 15amps PSU speaking i run a Nvdia 6600 GT and im not sure this whole disconnects and the loud CPU is a problem caused by PSU. Plz let me know what u think. i suck at computes and this is my first build... Thank u in advance
And btw its an AMD venice 3200+ in the box i bought it brand new and it says "ultra quiet technology"...
1 - 7 of 7 Posts
take the side pannel off and make sure its comming from ur cpu not ur videocards fan
how old is the computer? and has it been cleaned. if not then id takeit to a computer store get it cleaned out or if u have a air compressure use that. second what your PSU wattage, thridly what kind of loud noise is the cpus fan making
When your using SLi and a venice processor, your gonna need a new PSU. The one you have isnt going to cut it. You need an SLi compatible PSU, I would get this best bang for the buck period. Has adjustable fan controler, and the modular design is iceing on the cake
I ven been adviced to not use dual GPU's if im using the crappy PSU but u think after i buy a compatible SLI GPU the fans will cool off and make less sounds? because sometimes i like to leave my computer turned on for downloads and i cant sleep LOL thanks very much everyone
1 - 7 of 7 Posts
